Elherbinator Posted June 14, 2022 Report Share Posted June 14, 2022 (edited) 7 hours ago, jaimymac said: Looks great! I've been wanting to do the same on my D1! Product info GlowShift Gauges https://www.glowshiftdirect.com/gauge-types/ Pillar Pod https://www.glowshiftdirect.com/universal-dual-gauge-pillar-pod/ Water temp sensor adapter https://www.glowshiftdirect.com/34mm-1-5-16-water-sender-hose-attachment/ Oil sensor adapter to fit in timing chain cover NPT Fitting Adapter,Fitting... https://www.amazon.com/dp/B07YZKHDJ5?ref=ppx_pop_mob_ap_share Used these for easy wiring Recoil 10 Pack 12V Car... https://www.amazon.com/dp/B07WV8DG2F?ref=ppx_pop_mob_ap_share Edited June 14, 2022 by Elherbinator jaimymac 1 Link to comment Share on other sites More sharing options...
Elherbinator Posted June 20, 2022 Report Share Posted June 20, 2022 Installed a new master cylinder and proportioning valve. The only thing left if this doesn’t fix my braking issue would be the booster, but I don’t see how that could be the issue. jaimymac and Jethro 2 Link to comment Share on other sites More sharing options...
lutz Posted June 20, 2022 Report Share Posted June 20, 2022 56 minutes ago, Elherbinator said: Installed a new master cylinder and proportioning valve. The only thing left if this doesn’t fix my braking issue would be the booster, but I don’t see how that could be the issue. Most of the time on hydroboost its bad fluid or the ps pump is dead or not for a hydroboost .What are your symptoms? Link to comment Share on other sites More sharing options...
Elherbinator Posted June 20, 2022 Report Share Posted June 20, 2022 (edited) 38 minutes ago, lutz said: Most of the time on hydroboost its bad fluid or the ps pump is dead or not for a hydroboost .What are your symptoms? Doesn’t stop well, slows down ok. Feels like I can’t get enough pressure on the brakes. The pedal isn’t hard to depress. I can push it to the floor and still don’t get much stopping power Edited June 20, 2022 by Elherbinator Link to comment Share on other sites More sharing options...
MHARTD4 Posted June 20, 2022 Report Share Posted June 20, 2022 Installed a Gobi rack. It took 7 months wait but its worth it. Just need to decide roof light setup. OldCarSmell, jaimymac and El Chapomint 3 Link to comment Share on other sites More sharing options...
SLOHybrid Posted June 20, 2022 Report Share Posted June 20, 2022 (edited) 11 hours ago, Elherbinator said: Doesn’t stop well, slows down ok. Feels like I can’t get enough pressure on the brakes. The pedal isn’t hard to depress. I can push it to the floor and still don’t get much stopping power re: RRC a lot of nice looking work there! was the original pump running continuously? soft pedal is usually the pump not working efficiently. I have yet to change out a ABS modulator (they never fail) Edited June 20, 2022 by SLOHybrid Link to comment Share on other sites More sharing options...
Elherbinator Posted June 20, 2022 Report Share Posted June 20, 2022 re: RRC a lot of nice looking work there! was the original pump running continuously? soft pedal is usually the pump not working efficiently. I have yet to change out a ABS modulator (they never fail)I don’t have ABS, just a proportioning valve after the MCSent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
SLOHybrid Posted June 20, 2022 Report Share Posted June 20, 2022 1 hour ago, Elherbinator said: I don’t have ABS, just a proportioning valve after the MC Sent from my iPhone using Tapatalk this is a 95? assuming you changed all of this out as you were having brake issues and still are?? I am still running my pump and module without ABS & works great! just trying to help. Link to comment Share on other sites More sharing options...
Elherbinator Posted June 20, 2022 Report Share Posted June 20, 2022 this is a 95? assuming you changed all of this out as you were having brake issues and still are?? I am still running my pump and module without ABS & works great! just trying to help.I bought it with the brake system already hacked up. It hasn’t worked since I have had it. It has hydroboost and had a Massey Ferguson MC and am unknown proportioning valve. It also had super corroded calipers and hard lines at the wheels. I have since changed out everything but the hydroboost Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Elherbinator Posted June 20, 2022 Report Share Posted June 20, 2022 Serves me right. I should have known better than to buy a vehicle from some sketchy dude in Walnut Grove. First warning sign was seeing a burnt up Land Rover sitting in the driveway. Second was unusually large supply of White Claws yokrieger, Jethro and El Chapomint 3 Link to comment Share on other sites More sharing options...
jaimymac Posted June 21, 2022 Report Share Posted June 21, 2022 On 6/13/2022 at 8:24 PM, Elherbinator said: GlowShift Gauges https://www.glowshiftdirect.com/gauge-types/ Pillar Pod https://www.glowshiftdirect.com/universal-dual-gauge-pillar-pod/ Water temp sensor adapter https://www.glowshiftdirect.com/34mm-1-5-16-water-sender-hose-attachment/ Oil sensor adapter to fit in timing chain cover NPT Fitting Adapter,Fitting... https://www.amazon.com/dp/B07YZKHDJ5?ref=ppx_pop_mob_ap_share Used these for easy wiring Recoil 10 Pack 12V Car... https://www.amazon.com/dp/B07WV8DG2F?ref=ppx_pop_mob_ap_share Thanks Eric! Link to comment Share on other sites More sharing options...
LP Rover Posted June 22, 2022 Report Share Posted June 22, 2022 Well, what I did today was kicked myself for being a D2 owner. I'm now shopping for a short block. As luck would have it, the 2018 Western National Land Rover Rally rig is in need of a new engine. Why is that you might ask -- wasn't it a rebuilt engine? Very good questions for which I have no answers. What I do know is that I've got a lot of shop time into a bad engine block (so that's going to be a few grand), have machined heads, and am in need of a short block. Please let me know if you have any leads. . . . Mr.BlueSky 1 Link to comment Share on other sites More sharing options...
SLOHybrid Posted June 24, 2022 Report Share Posted June 24, 2022 went and bought another supercharged L322... I have 6 Rovers now. I need help!!! this is going to be my tow rig/overlander. SDS, El Chapomint, SplurGn and 1 other 4 Link to comment Share on other sites More sharing options...
Mr.BlueSky Posted June 24, 2022 Report Share Posted June 24, 2022 29 minutes ago, SLOHybrid said: went and bought another supercharged L322... I have 6 Rovers now. I need help!!! this is going to be my tow rig/overlander. Mmm... yes this is a problem and you do need help. Feel free to call me, I can extract some of these rovers off your hands. ; ) Link to comment Share on other sites More sharing options...
SplurGn Posted June 24, 2022 Report Share Posted June 24, 2022 48 minutes ago, SLOHybrid said: went and bought another supercharged L322... I have 6 Rovers now. I need help!!! this is going to be my tow rig/overlander. Nice stable! What is your weekly process? Do you take a different one out every day, or, is the trickle charger a must? Link to comment Share on other sites More sharing options...
SLOHybrid Posted June 24, 2022 Report Share Posted June 24, 2022 (edited) 26 minutes ago, SplurGn said: Nice stable! What is your weekly process? Do you take a different one out every day, or, is the trickle charger a must? no! the Classics have been sitting a lot lately! but under car covers ... the 08 (my Wife's) get's driven on friday's and the weekend... she has a 15 Golf TDi Wagon that is her commuter . I drive a Supercharged Mini Cooper S for a commuter which is a blast to drive. figured out we have 4 forced induction vehicles now.. I plan to drive the new purchase maybe once a week to work and use it on the weekends but that is usually reserved for my 25th. I have a rodent problem currently that needs to be stopped! they chewed up my registration in the 25th and made nests in the heater blower which involved me removing the entire cowl and creating a cover over the intake as it is stupidly exposed to the elements. see you guys on the trails. thx Edited June 24, 2022 by SLOHybrid Mr.BlueSky 1 Link to comment Share on other sites More sharing options...
Mr.BlueSky Posted June 24, 2022 Report Share Posted June 24, 2022 1 hour ago, SLOHybrid said: I have a rodent problem currently that needs to be stopped! they chewed up my registration in the 25th and made nests in the heater blower which involved me removing the entire cowl and creating a cover over the intake as it is stupidly exposed to the elements. see you guys on the trails. thx This sucks.... I recommend a Rover cat On the trickle charger side of things, I've found that as long as the electrical is in tip top shape, I haven't needed one on the classics. Snowflake (sadly) can go about two-three months without a startup. Fires every time. Eleven on the other hand almost always needs a charge within a week. Link to comment Share on other sites More sharing options...
El Chapomint Posted June 24, 2022 Report Share Posted June 24, 2022 7 hours ago, SLOHybrid said: went and bought another supercharged L322... I have 6 Rovers now. I need help!!! this is going to be my tow rig/overlander. It's perfect! Mr.BlueSky 1 Link to comment Share on other sites More sharing options...
SLOHybrid Posted June 24, 2022 Report Share Posted June 24, 2022 4 hours ago, Mr.BlueSky said: This sucks.... I recommend a Rover cat On the trickle charger side of things, I've found that as long as the electrical is in tip top shape, I haven't needed one on the classics. Snowflake (sadly) can go about two-three months without a startup. Fires every time. Eleven on the other hand almost always needs a charge within a week. I agree the classics always start Mr.BlueSky 1 Link to comment Share on other sites More sharing options...
SLOHybrid Posted June 24, 2022 Report Share Posted June 24, 2022 32 minutes ago, El Chapomint said: It's perfect! pretty much so... that will change😄 Mr.BlueSky 1 Link to comment Share on other sites More sharing options...
Elherbinator Posted June 27, 2022 Report Share Posted June 27, 2022 Put in the new reman steering box. Painted the pitman orange for strength. New drag link and steering stabilizer bracket. Jethro, So...Yoder and Mr.BlueSky 3 Link to comment Share on other sites More sharing options...
Elherbinator Posted June 27, 2022 Report Share Posted June 27, 2022 Did a chemical flush on the unstoppable classic’s cooling system. Get some decent sediment left over. RobertDingli 1 Link to comment Share on other sites More sharing options...
Elherbinator Posted June 30, 2022 Report Share Posted June 30, 2022 Made an adapter for my power bleeder to work with my new Wilwood Master cylinder. Figure it’s worth it since my brake work doesn’t appear over and this will save me time. Jethro and Mr.BlueSky 2 Link to comment Share on other sites More sharing options...
Elherbinator Posted July 4, 2022 Report Share Posted July 4, 2022 Happy Fourth! The RVRLNDR stops! Flushed the power steering fluid, bled the brakes, bled the power steering / hydroboost system, and voila! FullSizeRender.MOV Mr.BlueSky 1 Link to comment Share on other sites More sharing options...
SLOHybrid Posted July 6, 2022 Report Share Posted July 6, 2022 (edited) On 7/4/2022 at 12:56 PM, Elherbinator said: Happy Fourth! The RVRLNDR stops! Flushed the power steering fluid, bled the brakes, bled the power steering / hydroboost system, and voila! FullSizeRender.MOV awesome! now you need those wheels & tires Are you heading down the 1 to the July Morg this weekend? Edited July 6, 2022 by SLOHybrid Link to comment Share on other sites More sharing options...
