Elherbinator Posted August 13, 2021 Report Share Posted August 13, 2021 Hey D2 guys, let’s list the spare parts you have and can bring to the Rovicon. This was we can get a comprehensive amount of spares and leave some of the redundant parts at home. So list what you got. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Elherbinator Posted August 13, 2021 Author Report Share Posted August 13, 2021 (edited) I’m going to bring:Ashcroft HD axle shaftsHubSteering armsHosesCPSTension pulleyFuel pump Coolant reservoirCoil Pack Sent from my iPhone using Tapatalk Edited August 13, 2021 by Elherbinator Link to comment Share on other sites More sharing options...
RobertDingli Posted August 13, 2021 Report Share Posted August 13, 2021 Disco Stu Spare and Tools Spares Box - Pelican 1610 CaseEngine oil - 1 litreTrans fluid - 1 litreDiff oil - 2 litresWD40Carb cleanerBrake fluid - 350 ml x36 ton bottle jack RTV - diffRTV - general Thermostat and short hoseCV bootCV boot clipsTie Rod Ends - pairUni jointFunnel12 ft booster cablesHeavy duty ratchet strapAxle standDuct tapeBailing / fencing wire Hand cleanerGlovesD2 fuse boxPanhard rod bushO2 sensorsFuel capFan beltsKnock sensorsCrank position sensorCam position sensorSpark plugs (4)Brake caliper banjo bolts and washersCoolant T piece and bleeder screwAssorted bolts and screwsAssorted hose clampAssorted Zip tiesAssorted wireMultimeterSuperglueJB WeldTank repair kitElectrical tapeHeat shrinkAA and AAA batteries Tool Box - Rigid 22â€3/8†sockets + 32mm (D2 axle nut)15 mm and 19 mm 12 point sockets (D2 brake calipers)1/4†hex bitsAdjustable spanner (wrench)Spanners (wrenches)Cold chiselsVarious pliers and cutters HacksawVice gripsTrim removal toolsKnife sharpenerExtendable magnetSynthetic rope splicing toolMag lite Screw driversMultigrips (channel lock pliers)Allen keys - metric and imperialMeasuring tapeSmall ratchet strapEarplugs (good for sealing small holes)Zip tiesSuperglueLoctite Air line joiner fittings Assorted electrical crimp terminals Electrical tapeHeat shrinkSoldering iron (butane)ParacordAssorted hose clampsAssorted rubber o rings Assorted cotter pinsAssorted fuses and relays OtherTyre repair kitFirst aid kitShovelFit extinguisherRecovery gearTest light kitStarter MotorAlternatorCoolant HosesBrake lines Andrew Wood 1 Link to comment Share on other sites More sharing options...
Andrew Wood Posted August 14, 2021 Report Share Posted August 14, 2021 Between the two of you guys I don't have any thing to bring that would not be redundant except for ball joints, tie rod ends duck tape and bailing wire. The tools I will bring are my welder, angle grinder, drill, sawzall, impact gun, soldering iron. If I think of anything else I will post it. Jethro and RobertDingli 2 Link to comment Share on other sites More sharing options...
renelozano Posted August 15, 2021 Report Share Posted August 15, 2021 I’ll be taking-Spare sensors-All fuses our D2 uses-axles-CVs -Tensioner Pulley-Belts-Tools for most repairs including my CO2 tank and air tools for Axle Nuts-Spare Driveshaft for front Jethro and RobertDingli 2 Link to comment Share on other sites More sharing options...
Andrew Wood Posted August 16, 2021 Report Share Posted August 16, 2021 Adding to the list of stuff I'm bringing for the D2 are rear axle shafts and a alternator. Link to comment Share on other sites More sharing options...
