DiscoBears Posted February 28, 2016 Report Share Posted February 28, 2016 Jethro came over and we got the safari guard bumper on, winch on and operational (after a small fireworks show) took off faux sliders and prepped to get the new ones on and slapped on the 32 inch tires..Disco Bear is looking good...also threw on the bright orange grill...for now...can't wait to get shocks amd springs amongst a few other goodies... https://uploads.tapatalk-cdn.com/20160228/3ae328e408e2030340b59ddfae85f61e.jpghttps://uploads.tapatalk-cdn.com/20160228/d7e534bafa1a1649e86191345e7a9eb7.jpg Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
Disco2Guy Posted February 28, 2016 Report Share Posted February 28, 2016 Looking good! The orange grill is a nice touch. Looks like it ate a D2 G4 edition truck and the Tangiers paint is all over its teeth:) Link to comment Share on other sites More sharing options...
Justin Posted February 28, 2016 Report Share Posted February 28, 2016 Pouring out a little liquor . R.I.P d1 Glad someone got use of my old parts, looking good . Now I gotta get your lift over Link to comment Share on other sites More sharing options...
Jethro Posted February 29, 2016 Report Share Posted February 29, 2016 Yeah, it turned out great! Now he does need the lift or he'll be starting the fender trim for those 35s sooner than later with the newly acquired cutting tools! Link to comment Share on other sites More sharing options...
DHappel Posted February 29, 2016 Report Share Posted February 29, 2016 Gee, and they gave me grief over my orange shackles.... j/k - I dig it! Link to comment Share on other sites More sharing options...
DiscoBears Posted March 19, 2016 Author Report Share Posted March 19, 2016 The learning curve was once again lessened last night...passenger side spring took a whole day and cost me a few bumps and scrapes...the driver side front suspension took me two hours...hopefully I can get the rear done this weekend...woo hoo...btw the right tools for the right job right? Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
DiscoBears Posted March 19, 2016 Author Report Share Posted March 19, 2016 the ohhh thats how that works moment...a moment too late... Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
GraemeWare Posted March 19, 2016 Report Share Posted March 19, 2016 ... the ohhh thats how that works moment...a moment too late... No spring compressor needed. Disconnect the top damper (shock absorber) mounts and then jack up the vehicle on the chassis .... Regards, Graeme Link to comment Share on other sites More sharing options...
DiscoBears Posted March 19, 2016 Author Report Share Posted March 19, 2016 No spring compressor needed. Disconnect the top damper (shock absorber) mounts and then jack up the vehicle on the chassis .... Regards, GraemeLimited on the 13 inch jack I have...but I found a way....the back springs were significantly easier... Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
astateofmike Posted March 20, 2016 Report Share Posted March 20, 2016 I have driven to a loading dock and down a flex test. When the springs got loose, I swapped it out, moved on to the other corner... Link to comment Share on other sites More sharing options...
TomOwen Posted March 21, 2016 Report Share Posted March 21, 2016 I have driven to a loading dock and down a flex test. When the springs got loose, I swapped it out, moved on to the other corner...Haha! I put frame on jack stands and bottle jack between axel and body to push axel down enough to pop springs out, I like the ramp trick! Link to comment Share on other sites More sharing options...
DiscoBears Posted March 21, 2016 Author Report Share Posted March 21, 2016 I can almost visualize this...you mean just roll up to some shiiping warehouse that is closed on the weekend...drive up one side pop and replace...drive up other pop replace...did you remove the front shocks before hand?...I am open to tricks it just seems after this weekends experience...I need more specifics beyond...drive up a ramp and pop em off... Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
JFuller Posted March 21, 2016 Report Share Posted March 21, 2016 You can do it easier than that. First use the full height of the jack on the axle, and put a tall jack stand under the frame. Next remove tires, disconnect shocks and lower axles. They should just about hit the ground. Watch out for those brake lines. You don't actually have to reach the frame with your jack, just a stand. you can block up you jack a bit with some wood to get a few extra inches if you need it. Or swing by and you can use my jack and stands. I wont be able to help until after sunday though. Link to comment Share on other sites More sharing options...
astateofmike Posted March 21, 2016 Report Share Posted March 21, 2016 I can almost visualize this...you mean just roll up to some shiiping warehouse that is closed on the weekend...drive up one side pop and replace...drive up other pop replace...did you remove the front shocks before hand?...I am open to tricks it just seems after this weekends experience...I need more specifics beyond...drive up a ramp and pop em off... Sent from my SCH-I535 using Tapatalk On my 88, it is trickier as the shocks are in the middle of the front springs But yes. I had the mounts with the bolts off on the rear, drove up, angled and when I hear the spring start to go loose...I got out and put the new one in. each corner done, loose nut on the mounts etc to get home and off I went. The front, I have different front towers, so I just unbolted the towers and went shockless for the mile. Angle, ping goes the spring, replace and on my way. Worst part? Getting back into the truck when it is all tippy. Would be quicker with 2 people. Link to comment Share on other sites More sharing options...
lilcrawler Posted March 21, 2016 Report Share Posted March 21, 2016 I just put my rig on very tall jack stands and let the axle droop. Springs just came right out. Link to comment Share on other sites More sharing options...
DiscoBears Posted April 3, 2016 Author Report Share Posted April 3, 2016 Moved the winch controller from the front to the under carriage over the front armor...waterproof box and black silicone caulk where I drilled holes for the wires...did a test all works...moved the controller access next to logo...https://uploads.tapatalk-cdn.com/20160403/f9ff7ac84371841b57ea65fd8feea115.jpghttps://uploads.tapatalk-cdn.com/20160403/9b44e6074c0215dd23308341d8d2cc72.jpghttps://uploads.tapatalk-cdn.com/20160403/8878c5b0ef5fc63ce77d40e20f920cad.jpghttps://uploads.tapatalk-cdn.com/20160403/c836afbdd94776c78af9251b14dd0d2b.jpg Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
Jethro Posted April 4, 2016 Report Share Posted April 4, 2016 Looks really good, very clean setup. Now the double battery to run it!!! Link to comment Share on other sites More sharing options...
ndamico Posted April 4, 2016 Report Share Posted April 4, 2016 Way to keep the ball rolling matt Link to comment Share on other sites More sharing options...
DiscoBears Posted April 20, 2016 Author Report Share Posted April 20, 2016 Took a crack at some LEDs with a sound reactive controller lined the back for now...https://vimeo.com/163602509 Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
DHappel Posted April 21, 2016 Report Share Posted April 21, 2016 Taking the Disco part seriously eh? Link to comment Share on other sites More sharing options...
DiscoBears Posted April 21, 2016 Author Report Share Posted April 21, 2016 Taking the Disco part seriously eh?There never should have been any doubt... Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
DiscoBears Posted April 21, 2016 Author Report Share Posted April 21, 2016 Rear drive shaft and axle angle corrected...drives a lot smoother on the road... https://uploads.tapatalk-cdn.com/20160421/084c830eaba82503806da927a3e99db7.jpghttps://uploads.tapatalk-cdn.com/20160421/99864a7736178b6384c8aca5ff69d326.jpghttps://uploads.tapatalk-cdn.com/20160421/e0ba9f5de0430fcdd32653f1f172a1c0.jpg Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
AdvRovr Posted April 21, 2016 Report Share Posted April 21, 2016 Looks purdy. So, does that mean you're on for this weekend? If so, camping or just one day? Link to comment Share on other sites More sharing options...
DiscoBears Posted April 22, 2016 Author Report Share Posted April 22, 2016 Looks purdy. So, does that mean you're on for this weekend? If so, camping or just one day?Heading up there somewhere and meeting up if possible on Sunday... Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
JFuller Posted April 22, 2016 Report Share Posted April 22, 2016 That third picture, is that with the Drive shaft installed? How long is that slip yoke? Looks pretty extended but then I have never had a TW drive shaft so nothing to compare with what they usually build. Link to comment Share on other sites More sharing options...
