bandykins Posted March 9, 2020 Report Share Posted March 9, 2020 Just got my head gasket kit for the range rover classic. I see a few items I don't expect or recognize... it's a universal kit that also supports defenders, disco 1and 2 and p38... Sip, here goes. First picture is general overview. There are two small seals similar in size to the injector o rings...? Small square sealing rings...? Large square sealing rings...? Crush washers (one is my oil plug) the other 3... ? Two large o rings... ? And last but not least, the two gaskets pictured with the simple thermostat gasket... ? Thanks for the help. I called British Atlantic to ask what was in the gasket kit I bought FROM THEM... they said, I dunno maybe check on the forums.... Sent from my SM-G970U1 using Tapatalk Link to comment Share on other sites More sharing options...
DHappel Posted March 10, 2020 Report Share Posted March 10, 2020 Honestly, I got nuthin. I sadly have to admit I've never had the heads off a Rover engine so I'm not going to be a lot of help. But in general, as you pull it apart you should see what comes off and what you'll need from the kit to put it back. (ahem) How hard can it be? Mr.BlueSky and bandykins 2 Link to comment Share on other sites More sharing options...
bandykins Posted March 11, 2020 Author Report Share Posted March 11, 2020 Honestly, I got nuthin. I sadly have to admit I've never had the heads off a Rover engine so I'm not going to be a lot of help. But in general, as you pull it apart you should see what comes off and what you'll need from the kit to put it back. (ahem) How hard can it be?I've located most but I don't want tofind that after I've put it back together there was a part I should have dug out and replaced (think valve stem seals but less obvious lol...) I figured out a couple of the gaskets with the thermostat. They came off first and I had over looked them... Would have been nice to have a parts list or description :-) Sent from my SM-G970U1 using Tapatalk Link to comment Share on other sites More sharing options...
DHappel Posted March 12, 2020 Report Share Posted March 12, 2020 Where's that Hayne's manual when you need it? (I actually have one for the RRC/D1, but nothing for the D2/P38 stuff) Link to comment Share on other sites More sharing options...
SLOHybrid Posted March 12, 2020 Report Share Posted March 12, 2020 (edited) CALL ME Edited March 16, 2020 by SLOHybrid Link to comment Share on other sites More sharing options...
