jlmoped Posted October 25, 2017 Report Share Posted October 25, 2017 Last week I put the LR4 in off-road height to examine the lift rods. I didn't change the lift rods. I left it at that height for about 5-6 days. Yesterday while driving it at the off-road height I noticed a new noise near the driver side rear wheel/suspension. It sounded like a rattling tin can. Is that from the thin metal shield around the air suspension surrounding the air bladder? Is that the sway bar or something loose? When I lowered it to normal height or access height the noise went away. When it went back up to off-road height, noise came back. Going left, right or straight made no difference on the noise, so more likely to be just the suspension going up and down. Is there a problem leaving the suspension in off-road height for too long? I wouldn't think so since others have installed the lift rods so it is at the "off-road" height all the time. So what is this new noise and what to look for and fix? Thanks,Julian Link to comment Share on other sites More sharing options...
DHappel Posted October 25, 2017 Report Share Posted October 25, 2017 I can't say what the noise is without seeing it, but you are right that leaving it at off road height should not cause any issues. It is possible the shield is rattling but I wouldn't expect it to be the source off the top of my head. Link to comment Share on other sites More sharing options...
Gotrovr Posted October 25, 2017 Report Share Posted October 25, 2017 Is this noise constant or intermittent? Does this noise increase in pitch with an increase in speed? Does this noise vary in loudness with speed?, i.e. higher the speed the louder the noise Link to comment Share on other sites More sharing options...
jlmoped Posted October 25, 2017 Author Report Share Posted October 25, 2017 Hi Will, Noise is intermittent. After driving for a while it happened less frequently. Pitch and loudness didn't change with speed. Slight unevenness of road surface trigger the noise intermittently. Only happens at off-road height. Did your Donkey get new shoe (passenger rear tire)? Thanks for showing us around at the Annual. Thanks,Julian Link to comment Share on other sites More sharing options...
AdvRovr Posted October 25, 2017 Report Share Posted October 25, 2017 I'm going to guess it's a heat shield for the exhaust. There are quite a few of them along the exhaust routing and it's possible that something is pinching it still while in standard height, but moves enough to let it rattle at offroad height. Link to comment Share on other sites More sharing options...
Gotrovr Posted October 26, 2017 Report Share Posted October 26, 2017 Hi Will, Noise is intermittent. After driving for a while it happened less frequently. Pitch and loudness didn't change with speed. Slight unevenness of road surface trigger the noise intermittently. Only happens at off-road height. Did your Donkey get new shoe (passenger rear tire)? Thanks for showing us around at the Annual. Thanks,Julian Intermittent, decrease over time, bump induced and dependent on increased drive height. I'm thinking what ever is making this noise is temperature sensitive and not securely fastened or ajar. Sounds like a heat shield or accessory item mounted near a drive shaft. As for Donkey, I still have a few spare tires left to be mounted. As for new, I'm going to rethink my tire choice (Duratrac) due to frequent side wall cuts Link to comment Share on other sites More sharing options...
