Gotrovr Posted January 27, 2008 Report Share Posted January 27, 2008 Shrek passed his smog check up Gives me the green light to upgrade tires not having to spend more money at Cerrone's for engine work... Hey, I'm on a budget like everyone else.. Link to comment Share on other sites More sharing options...
PCRover Posted January 27, 2008 Report Share Posted January 27, 2008 Nice! What are you looking for new tire choices? Link to comment Share on other sites More sharing options...
Gotrovr Posted January 27, 2008 Author Report Share Posted January 27, 2008 Nice! What are you looking for new tire choices? basically I need a 33" tire Easy route is to stay with current wolf steelee's 6.5x16 and go with 255/85 BFG MT. 285's and up would require new wheels at least 7" or more preferable 8" wide. 2 things I have yet to accomplish before tires1) trim the front part of my Rovertyme sliders to eliminate potential wheel rub and 2) purchase an adapter mount for larger spare tire rather than turn the current mount upside down. Link to comment Share on other sites More sharing options...
keptin Posted January 27, 2008 Report Share Posted January 27, 2008 Eck...adapter mount.<enter standard carrier adapter argument here>....you've all heard it. "Yippee-ki-yay" NSFW (cussing...obviously) Link to comment Share on other sites More sharing options...
PCRover Posted January 27, 2008 Report Share Posted January 27, 2008 Lots of defender owners put 285's on 6.5" wheels so it can be done. Tony can get steel wheels fairly cheap so you could consider new wheels into your tire budget. But of course 255 M/T's are a time proved tire that would work great. Link to comment Share on other sites More sharing options...
LandRonB Posted January 27, 2008 Report Share Posted January 27, 2008 Not now, but my 04 D2 will eventually get a lift and larger tires. Good to have another wheeler with same size tires. So might be re-reading this post sometime in the near future! Link to comment Share on other sites More sharing options...
PCRover Posted January 27, 2008 Report Share Posted January 27, 2008 You will need a full 3" lift to fit 33's with factory alloys, and even higher if you went to after market steel wheels. Link to comment Share on other sites More sharing options...
esteban Posted January 27, 2008 Report Share Posted January 27, 2008 Congrats on passing smog, were you really worried it wouldn't pass?255/85s are my next tire choice also.....along with 4.11s and hd axles. Steve Link to comment Share on other sites More sharing options...
LandRonB Posted January 27, 2008 Report Share Posted January 27, 2008 You will need a full 3" lift to fit 33's with factory alloys, and even higher if you went to after market steel wheels. Yup! Thx Gary! Setting aside funds now. Will be talking to Tony when the time comes. I also like the Rovertym rear bumper for DIIs: http://www.rovertym.com/d2rearbumper.htm Link to comment Share on other sites More sharing options...
stevenmd Posted January 27, 2008 Report Share Posted January 27, 2008 You will need a full 3" lift to fit 33's with factory alloys, and even higher if you went to after market steel wheels. What is your thinking behind that Gary? After-market steel wheels usually have an offset but you would also need spacers to run 33's on alloys. My Trek steelies have an offset (10mm I think). Are you thinking that more is needed for steel wheel for stuffing the tire up into the fender well? Wouldn't longer bumpstops take care of some of that? But then you'd lose some travel with down travel being related to the up travel of the opposite wheel. My current tires waiting to go on at 13.5" wide (33's). Wider than I want but I got a good deal on them already mounted to the Trek rims. I may go ahead with some 10.5" 35's instead and sell the 33's on craigslist... Link to comment Share on other sites More sharing options...
PCRover Posted January 27, 2008 Report Share Posted January 27, 2008 With 3" lift, no sway bar, steel wheels and 285/75's you get rubbing on the rear fenders on a DII, just ask Chuck. This is because of the reduced offset forcing the tires to far out. With a 3" lift, stock alloys and 285/75's I never had a rubbing issue on my DII. I imagine you could limit your suspension travel with Bump stops, sway bars etc and eliminate the rubbing, but you are giving up articulation. It is a personal choice thing. Link to comment Share on other sites More sharing options...
stevenmd Posted January 27, 2008 Report Share Posted January 27, 2008 I just realized you were talking about DII's. I think the rangies have a little more wiggle room... we shall soon see! Link to comment Share on other sites More sharing options...
PCRover Posted January 27, 2008 Report Share Posted January 27, 2008 Come on Steven, you have to get out of that RRC haze and remember there are other Land Rovers in service. You RRC guys are getting out of control! Link to comment Share on other sites More sharing options...
Desertcrawler Posted January 27, 2008 Report Share Posted January 27, 2008 with alloy wheels unless you have some sort of spacer or offset rims. The offset rims I have push things out a bit too far, ergo more rubbing. I am not sure if I was only pushed out with the spacers I had and my alloy wheels if I would still be OK or not - i think I probably would. Another option would be to find a tire that was skinnier but still gave you the height you are looking for out of 285/75s -- I am not sure what the actual tire size would be.. - Link to comment Share on other sites More sharing options...
PCRover Posted January 28, 2008 Report Share Posted January 28, 2008 That's odd Chuck, I had them on my 3" DII with no troubles and no wheel spacers on stock alloys. Link to comment Share on other sites More sharing options...
Gotrovr Posted January 28, 2008 Author Report Share Posted January 28, 2008 Congrats on passing smog, were you really worried it wouldn't pass?255/85s are my next tire choice also.....along with 4.11s and hd axles. Steve Yes, I'm a little gun shy sort of speak... long history, saving story for a camp fire Link to comment Share on other sites More sharing options...
