nengelbrecht6 Posted July 5, 2017 Report Share Posted July 5, 2017 Been getting the following fault code from the IID and finally deciding to do something about it: P0501-62 (E8) Vehicle Speed Sensor A range/performance - Algorithm based failure - signal compare failure This is accompanied with "Engine System Fault" and "Cruise Control not Permitted" messages. I am assuming this is pointing to a fault in one of the wheel speed sensors, but which one is "Speed Sensor A"? Link to comment Share on other sites More sharing options...
Volkov Posted July 6, 2017 Report Share Posted July 6, 2017 My speed sensor failure told me which wheel, but it also shut down a bunch of systems. I had no speedo, air suspension, or traction control Link to comment Share on other sites More sharing options...
Justin Posted July 7, 2017 Report Share Posted July 7, 2017 I'll check with our rover software tomorrow and get back to you with an update. Link to comment Share on other sites More sharing options...
DHappel Posted July 7, 2017 Report Share Posted July 7, 2017 That's a bit odd - I haven't seen an 'A' sensor before. Usually it tells me LF, LR, etc Link to comment Share on other sites More sharing options...
nengelbrecht6 Posted July 7, 2017 Author Report Share Posted July 7, 2017 I don't lose any functionality when I get the error. Only thing I lose is the ability to use cruise control. And I get the annoying "Engine System Malfunction" warning message that continually appears. Yesterday on the way home I got the same "Engine System Malfunction" message, so I plugged in the IID. This time, no speed sensor fault. Not sure now if the warning message is being caused by something else, but I don't have any faults coming up on the IID. And I haven't lost any functionality. Just the annoying message. Link to comment Share on other sites More sharing options...
nengelbrecht6 Posted September 6, 2017 Author Report Share Posted September 6, 2017 I'll check with our rover software tomorrow and get back to you with an update. Justin, Pulling up an old thread, but can you check this out and let me know? Still getting the same error code from time to time. Thanks,Nick Link to comment Share on other sites More sharing options...
