ChrisJB Posted December 14, 2007 Report Share Posted December 14, 2007 Would like to get some input on what are some of the basic things that a person whould have with them while 4 wheeling to aid in recovery and to be able to handle most issues that may arise. Of course I always bring lots of water, first aid kit, and cooler full of beer I also carry an air compressor and have fiited a shackle bracket into my rear hitch receiver. So would like some input on what items I should really have with me. Link to comment Share on other sites More sharing options...
astateofmike Posted December 14, 2007 Report Share Posted December 14, 2007 A shovel of some sort, either camping or full size on the rack. A recovery strap and a couple d rings to connect to a recovery vehicle. A winch, even a manual one, is a good idea. Communication device: Cell phone or better CB or BEST Sat phone / Ham radio. A good map, not just a gps, an actual map and compass....for when it gets REALLY bad. A "spares" bag is nice.....space blanket, change of clothes. Mountian Money, and a few of them. Used to clean cuts, wipe eyes, and for the obvious reasons too....and it can be traded I have found for other needed things. Link to comment Share on other sites More sharing options...
ChrisJB Posted December 14, 2007 Author Report Share Posted December 14, 2007 When it comes to adding accessories like winches and what not. Does it have any effect on the vehicles warranty? I have a warranty till 2011 and don't really want to do anything that may void it. Link to comment Share on other sites More sharing options...
Gotrovr Posted December 15, 2007 Report Share Posted December 15, 2007 When it comes to adding accessories like winches and what not. Does it have any effect on the vehicles warranty? I have a warranty till 2011 and don't really want to do anything that may void it. Modifications to the drive train ie lockers will impact the warranty but only with the replaced or upgraded items but not items that remain stock. Adding aftermarket accessories like a winch or rack is not a problem, these can be factory or dealer installed accessories. However, certain winches require special mounting to aftermarket bumpers that may not be compatable with the Supplementary Restraint System. I believe ARB makes an SRS compatable winch bumpers. Others might want to chime in here.... Link to comment Share on other sites More sharing options...
HMBRover Posted December 15, 2007 Report Share Posted December 15, 2007 I use milk crates to corral most of my off-road gear. I find they're easy to load and stack well in the garage when not on the road. Here's most of the stuff I drag along on an off-road trip. Spares crate contains:- top-off quantities of all fluids- tire patch kit- radiator hose patch kit- tail pipe/muffler patch kit- a few fuses of each required size- brake light switch (brake light switch must work to shift out of PARK)- quick setting epoxy- duct tape- bundle of wire and crimp connectors- electrical tape- spare rotoflex joint for rear drive shaft- spare serpentine belt (the old one from my 45K service)- hose clamps of various sizes- a few lengths of rubber tubing of various sizes- air filter- WD40- zip ties and steel wire Tool bag includes basic tools, wrenches, sockets and ratchets, OBDII Scanner, multi-meter, air compressor, matches, knife, flashlight. For longer trips I augment it with full 1/2" drive socket set, torque wrench, breaker bar. Recovery bags include 4 shackles, 2 tow straps, tree strap, 15 ft 3/8" G43 chain, HiLift jack accessories, gloves Storage bins contain tarps, hatchet, folding shovel, pruning saw, coveralls, 50 ft 5/8" truck rope, ratchet tie-downs, first aid kit, rags, gloves Survival crate contains Coleman backpack stove & fuel, couple cans of soup, pan, coffee bags, plastic bags (toxic spill kit), tent pegs and line to rig awning, 12vdc/110vac converter, AA battery charger, bug spray Water crate contains 4 gallon milk jugs of water Sleeping bag if temperature is near freezing or below Cooler with water, soda, beer, perishable foods (depends on trip length) Food crate with dry stuffs and cans (depends on trip length) I also carry a full-size shovel and axe as well as a 48" HiLift jack mounted on the roof rack. Hope this gives you some ideas. Obviously you don't need all this stuff each trip and it depends on what kind of trips you take, what you need. We do a lot of solo trips to out-of-the-way places so self-sufficiency is a must. Link to comment Share on other sites More sharing options...
stevenmd Posted December 15, 2007 Report Share Posted December 15, 2007 Front and rear recovery points should be the first thing you do. Never go out alone. Carry a few recovery straps. If you don't want to fit a winch, get a HiLift - they are pretty cheap at Tractor Supply Store or at 4-Wheel Parts stores. They can be used as a manual winch - slow but better than nothing. As for survival stuff, Brian (HMB) has it pretty much covered. Link to comment Share on other sites More sharing options...
ChrisJB Posted December 15, 2007 Author Report Share Posted December 15, 2007 Thank you very much for all the advice. Now when i go to my local Cabela's and walmart, i'll at least have a good shopping list Link to comment Share on other sites More sharing options...
astateofmike Posted December 16, 2007 Report Share Posted December 16, 2007 I am working on a new packing method for my truck....I like the crate idea, durable, consistantly sized and they do stack well...now will the local grocery let a few go? Link to comment Share on other sites More sharing options...
HMBRover Posted December 16, 2007 Report Share Posted December 16, 2007 They are a little hard to come by but I got most of mine at garage sales. The down side of them is they don't keep the dust out so if you go wheeling and the truck fills with dust then everything in the crates is dusty. I lined one of mine with 1/8 masonite to store dishes in. That works pretty well. Link to comment Share on other sites More sharing options...
astateofmike Posted December 17, 2007 Report Share Posted December 17, 2007 I know Ron (CT110) had some "tuffy" boxes that had lids/were sealed but were smaller than average. My RRC and I need to work some things out. No tiedowns in the back...that blows. I want to put 1/2 Cot Tents on the roof rack forward, then other items in the rear. I would like to bring the spare tire back into the truck, or on a swing away on a new rear bumper. I also need a good place for gas cans. If we are not "extreme offroading" but more adventuring, I have one of those racks that goes in the recvr hitch which I will use for gas water, as it will hold like 400#....but it doesn't swing away. I need to find an old swing away yakima or thule rack, hack off at the "bike part" and weld on a small platform. That is my goal Link to comment Share on other sites More sharing options...
ChrisJB Posted December 20, 2007 Author Report Share Posted December 20, 2007 So I did some shopping and this is what I picked up so far PROCOMP Universal Recovery Strap 2x20 20,000lb Rating 4 3/4" D-ring Shackles w/Screw Pins 142 Piece Auto Tool SetBackpack filled with survival and first aid goodies. (can survive 4 days food, water, shelter, first aide)Delorme Atlas and maps of Nevada and California from treadlightly.orgMap Compass2 6gal water containersportable water filter4.25 lbs fire extinguisherpair of mechanix glovesduct tape This is all in addition to the air compressor and roadside emergency kit that i already have Working on next getting misc stuff like fuses, tire repair kit, I think it's a good start so far. All this gear and it's making want to go out and get stuck or lost Link to comment Share on other sites More sharing options...
Gotrovr Posted December 20, 2007 Report Share Posted December 20, 2007 Murphy's Law #103 If you bring it, most likely you won't need it Link to comment Share on other sites More sharing options...
PCRover Posted December 20, 2007 Report Share Posted December 20, 2007 Nice list Chris, you will be well equipped. Link to comment Share on other sites More sharing options...
jhmover Posted January 9, 2008 Report Share Posted January 9, 2008 I've been using these for storage, they fit in the back, you can stack them, they're water and air tight (they come with a bleeder screw because they'll get so much vacuum in them you can't get the lid off), a little black paint and they look OK. http://www.galleria-e.com/cgi-bin/Colemans.storefront/en/product/133301 Link to comment Share on other sites More sharing options...
PCRover Posted January 9, 2008 Report Share Posted January 9, 2008 Nice, They are even aluminum to make them lite... Link to comment Share on other sites More sharing options...
DiscoChef Posted January 16, 2008 Report Share Posted January 16, 2008 Just drive behind any Safeway late at night. I got a few extra ones, if you need some let me know. Enrique Link to comment Share on other sites More sharing options...
astateofmike Posted January 16, 2008 Report Share Posted January 16, 2008 Yeah, but in a faster car than my rover....... I need to come up with a nice packing strategy...Just got 2 double Kamp Rite Tent Cots....one for girls, one for me and future child, dog for now. I think they are wider than my rack, by an inch......so much for tire and tents on the roof... I need to figure out something to do with that spare tire, since it is a 265/75...I must now commit to the rear bumper/tire carrier build. Then all will be good. Link to comment Share on other sites More sharing options...
stevenmd Posted January 17, 2008 Report Share Posted January 17, 2008 I've been using these for storage, they fit in the back, you can stack them, they're water and air tight (they come with a bleeder screw because they'll get so much vacuum in them you can't get the lid off), a little black paint and they look OK. http://www.galleria-e.com/cgi-bin/Colemans.storefront/en/product/133301 What was the shipping cost on those?:cool: Link to comment Share on other sites More sharing options...
Desertcrawler Posted January 18, 2008 Report Share Posted January 18, 2008 I also carry along FRS radios (cause they carry farther than CB). Plus one of those "PowerStation" batteries that doubles as a tire pump cause I am always afraid I might drain my battery in middle of nowhere. Link to comment Share on other sites More sharing options...
ChrisJB Posted January 19, 2008 Author Report Share Posted January 19, 2008 Do you need to have an FCC license for FRS radios still? I remember 5 years ago while working retail i was told by a motorola rep that any radio set with range of 5 miles and longer requires a license. Dont know if thats still the case Link to comment Share on other sites More sharing options...
astateofmike Posted January 19, 2008 Report Share Posted January 19, 2008 No, no need for a FCC license for FRS, or CB just HAM... Link to comment Share on other sites More sharing options...
jhmover Posted January 19, 2008 Report Share Posted January 19, 2008 Stevem I don't even remember the shipping costs I've had them for several years. They now have some different sizes, too. They're light and waterproof, so air tight they have a bleeder screw on them to let out the vacuuum when you open them. I keep tools, spare parts, etc., in one, then survival and medical gear in the other. Link to comment Share on other sites More sharing options...
