Disco2Guy Posted June 16, 2008 Report Share Posted June 16, 2008 Hello-I lubed my front drive shaft last night for the first time and saw the zerk on the slip shaft is missing. I don't know if it unscrewed itself or (possibly) got knocked off by the cat. Should I just grab some zerks from Kragen and use a little locktite on the fitting (taking care to not plug the hole of course!!)? What the best way to remove the dirt and lube from around the hole? Thanks Link to comment Share on other sites More sharing options...
HMBRover Posted June 16, 2008 Report Share Posted June 16, 2008 Mine came with a little Allen-head plug in place of the zerk. I just bought a pack of zerks at the auto parts store and put one in whenever I grease it and then replace it with the plug afterwards. If you leave the zerk in there you run the risk of it hitting the cats and possibly doing some damage. I think the zerk is a 6 mm metric thread but I bought 1/4 28 and they will screw in well enough to work. HTH Link to comment Share on other sites More sharing options...
Disco2Guy Posted June 16, 2008 Author Report Share Posted June 16, 2008 Thanks Brian. Have you seen any of those plugs for sale? I don't remember seeing any at Kragen where the other zerks are. Link to comment Share on other sites More sharing options...
HMBRover Posted June 17, 2008 Report Share Posted June 17, 2008 No. It looks like a set screw about 1/4" long. You might be able to find one at a good hardware store but finding a metric set screw is gonna be a challenge. You could modify one of the zerks in the package you buy by cutting off most of it. I think its OK to let it stick out a little but not the full length of the zerk. All the plug is really designed to do is keep dirt out of the slip joint. Link to comment Share on other sites More sharing options...
Disco2Guy Posted June 17, 2008 Author Report Share Posted June 17, 2008 That's a good idea. I'll pick up a box of zerks and get something in there a little shorter. Thanks HMBrian!! Link to comment Share on other sites More sharing options...
astateofmike Posted March 20, 2009 Report Share Posted March 20, 2009 NCLR 4th QaurterBOD Min.NCLR 2008 4th Qtr BOD Min..pdf Link to comment Share on other sites More sharing options...
PCRover Posted March 21, 2009 Report Share Posted March 21, 2009 Thanks Mike! Link to comment Share on other sites More sharing options...
