Tracktorking Posted May 29, 2008 Report Share Posted May 29, 2008 Hey allI need to replace my right side Cat Converter, it ticking like crazy at idle.Im looking for any suggestions as to cheap aftermarkets, I have a welder and grinder but Ive never done this myself but I would like to. I know I can get a bolt on but they are a little more expensive than welding a universal. Either way, any input on this would be great Link to comment Share on other sites More sharing options...
ChrisJB Posted May 29, 2008 Report Share Posted May 29, 2008 I was going to suggest replacing the cat with a dog but then i read the article so i'll save that whitty comment for another time I have used a bolt on cat before on a past car. The only reason why most muffler shops prefer to weld is to prevent leaks in the exhaust system as exhaust can penetrate the cabin area and cause effects on it's passengers. What I did to prevent leaks I put a a very thin amount of ceramic sealer on the exhaust tube going into the cat. The clamp, you want it tight enough to have the cat not fall off. If you over tighten then you can cause the exhaust tube to disform and not have a hight seal. Just for the ease of install, I have prefered the bolt on cat at that moment in time. I picked mine up at a local Midas for about $150 with clamps but it was for a economy car. Link to comment Share on other sites More sharing options...
Disco2Guy Posted May 29, 2008 Report Share Posted May 29, 2008 Not sure if this is what you're looking for, but it was posted on DWeb a week or two ago. http://www.discoweb.org/cats.htm Link to comment Share on other sites More sharing options...
Tracktorking Posted June 1, 2008 Author Report Share Posted June 1, 2008 Thanks for the great article. The Rover has a seperate bolt on CAT so I dont have to remove the whole Y section. Ill probably spend the extra dough and just do the bolt on thing as it look fairly simple, I crawled under there today to check it out. The noise only comes at idle and within a few minutes after start up. Seems like when the exhaust is just getting hot. I tried the screw trick but it lasted about 5 minutes before the sound came back. Link to comment Share on other sites More sharing options...
stevenmd Posted June 1, 2008 Report Share Posted June 1, 2008 http://www.completeexhaust.com - you can get one for around 50 bucks, weld it in Link to comment Share on other sites More sharing options...
esteban Posted June 2, 2008 Report Share Posted June 2, 2008 Ticking when it's cold? And goes away when hot? Could just be an exhaust leak at one of the flanges. Run your hand around the flanges on first start up and see if you can feel air coming out someplace. If the cat is bad, when you bang on it it will sound like it's filled with sand. Good luck! Steve Link to comment Share on other sites More sharing options...
Tracktorking Posted June 2, 2008 Author Report Share Posted June 2, 2008 No noother way around. Quite when its first started (cold) and starts making a rattling sound in about 3-5mins, but more like the exhaust gas pressure is rattling something. Sounds like a loose piece of metal clanging on metal (steel) like a clack clack clack clack, but once you step on the gas a little it goes away as if the pressure form exhaust gas is strong enough to seat it in place. Seems like as soon as the pipes heat up the noise starts. I had a bad plug on that side a month ago and I think it just shoot alot of unburned fuel through the cat and burned it out. Link to comment Share on other sites More sharing options...
Tracktorking Posted June 2, 2008 Author Report Share Posted June 2, 2008 Well I broke down and paid to have someone to do it. $190 installed in 30minsIt was a fair price me thinks. Link to comment Share on other sites More sharing options...
