mirowsky Posted December 27, 2018 Report Share Posted December 27, 2018 I've moved to a new condo and want to use the LR4 built-in transmitter to open the garage door. I can't get the LR4 to copy the hand-shake between transmitter and controller. The system uses Linear Act 31B fob transmitters. Each has a unique number that has to be programmed into the controller that opens the door, which I know how to do (It is a fixed number, not a rolling one). Has anyone solved this problem? Any suggestions on what to try? Link to comment Share on other sites More sharing options...
lithium1330 Posted December 28, 2018 Report Share Posted December 28, 2018 I thought homelink (I assume that's what LR uses also) is pretty much compatible with most residential garage door opener... Have you seen this post on programming steps? http://nortekcontrol.knowledgebase.co/article.php?id=321 I've had mix results whenever I have to re-program my garage door opener with homelink on my other car. Some times I take too long between pushing the button on the opener (hop down the ladder) and the homelink (in the car). So, i have to do it a few times before Homelink learns it. Good luck! Link to comment Share on other sites More sharing options...
mirowsky Posted December 28, 2018 Author Report Share Posted December 28, 2018 Chris: Wow. No wonder I had no luck. Thanks for the lead. I'll try it. John Link to comment Share on other sites More sharing options...
