Tyler Mattson Posted December 28, 2022 Report Share Posted December 28, 2022 Ok rover gurus I need some knowledge I recently got a new to me d1 and it has rovertyme rear trailing arms that are well worn in. So the bushings are pretty much not there and my question is does anyone know if the rovertyme rear trailing arms use a special bushing or is it just a stock rover. Thanks Link to comment Share on other sites More sharing options...
Jethro Posted December 28, 2022 Report Share Posted December 28, 2022 13 hours ago, Renorover said: Ok rover gurus I need some knowledge I recently got a new to me d1 and it has rovertyme rear trailing arms that are well worn in. So the bushings are pretty much not there and my question is does anyone know if the rovertyme rear trailing arms use a special bushing or is it just a stock rover. Thanks I had them on the black RRC, I had to swap them out and went with the poly bushings...super simple install as they are two pieces and didn't require a press. Link to comment Share on other sites More sharing options...
lutz Posted December 29, 2022 Report Share Posted December 29, 2022 They just take stock Bush NTC1772 .Poly is a good choice Link to comment Share on other sites More sharing options...
