ALWVSN Posted August 8, 2021 Report Share Posted August 8, 2021 I’m a little desperate to get this truck running. I had an engine block sleeve issue so I’m looking for a replacement. i know British Atlantic sells a complete block but it’s way out of my budget. Car / Mechanic is located in Fresno, but I’m located in NorCal. I can pick it up. Thanks Link to comment Share on other sites More sharing options...
Elherbinator Posted August 8, 2021 Report Share Posted August 8, 2021 (edited) Consider the LS swap route. They have kits available that allows you to use your stock electronics making it a very smooth swap. Plus it should be able to be smogged assuming you can get past the visual. There are several companies out there. I am somewhat familiar with Trailhead 4x4’s kit. Definitely worth looking into. Benefits would be more power, better mpg’s, and much more reliable. Basically a huge upgrade Sent from my iPhone using Tapatalk Edited August 8, 2021 by Elherbinator Mr.BlueSky and ALWVSN 2 Link to comment Share on other sites More sharing options...
