Winscott Posted June 14, 2021 Report Share Posted June 14, 2021 I have a 94 D90 ST NAS that is in good shape but I have begun to modify and restore it. In case you are interested in following along you can check out my blog which journals the progress. https://www.siliconvalleymotorclub.com/defender-90-build Here is the plan:suspension and tire upgrade (done)add some body armor (done)rock slidersreplace the bumper and add a winchrestore an original bench rear seat and add it to the truckrestore/replace the front seatsmodify the cubbyrestore the dashadd a fiberglass hard top for winter useMy goal is to make improvements here and there while keeping a lot stock. When I go aftermarket I will mostly do bolt-on and if I do it right I wont cross the line where you start to diverge from the spirt of the truck. Elherbinator 1 Link to comment Share on other sites More sharing options...
